1200 vs 1800 KV Hobbywing Quicrun Fusion SE
ZachVal
canada
I have a relatively stock Enduro Sendero RTR (2019) that I want to upgrade with a new motor. I want to stay with the same pinion, which I believe is 18t. I'm hoping to see better torque but maintain the current top speed or slightly increase it. I am running the dreaded NIMH; I don't know which one to choose. I don't want it to be overly fast, and I saw that 1200kv is better for run time. I'm currently getting 2 hours out of one battery. Thanks for your help and suggestions.
2 hours out of a NIMH? 1200kv turns slower (but I believe it has the same steps as the 1800 per volt, so no change there), so slower speed = less battery usage. Your pinion would not really have to change either.
yea i have two 7.4v 3000mah, i can go for a whole night with them. so im seeing that the original motor a 16t 5-slot has a comparable KV of 3500. i’m worried about the 1200kv and the 1800kv for that matter are going to be significantly slower. i’m new to this RPM motor stuff and gearing.
Keep reading about motors your numbers are a bit off, but on the right track. A bit slower but only when throttle is wide open. Why switch?
I’d look here
My research came up with the reedy 16t 5 slot original motor in my son's gatekeeper was about 1600kv equivalence.
Personally, I'd go 1800kv (I have 2 of them). I use the extra wheel speed to get up loose, low traction hills or bump up a ledge way more than I need super low speed torque.
You can always go up or down a tooth or two on the pinion. They're cheap enough I keep a selection around just in case I want to try something different.
Element uses 48p pinions. Robinson are good. Don't need the extra strong one since the spur is plastic.
I own all 2 in 1 systems. 1800 is what I would suggest unless.
I really like the 1200 and 1400 for the slow technical situations but miss the extra wheel speed when I need it.
Now if they were rated to 4s lips that would be awesome!!
I think i picked up my 1200kv 2 in 1 when it went on sale for <$48 a few months ago just to try out.
I mean the HW1040 and a motor would cost that and maybe more.
Did you replace the stock motor screws with shorter ones? I have an Element Trailwalker and thinking about a Fusion SE 1800KV. I believe the stock Trailwalker motor screws are 3X10mm. I am told they are too long for the Fusion brushless motor and need 3x6mm screws.
Somewhere I heard to use 1200vk for straight axles and 1800vk for portal axles. I have two of the 1200vks. One in my SE trail truck no underdrive at all and I believe a 22t pinion on 3s. Lots of speed but still has that low speed crawl as well.
The other is in my ifs mullet and the stock pinion from the SE on 3s. its ok not sure if it is the motor or maybe need a different pinion but I mainly just crawl with it. So the lower top speed really isn't a big deal. It still has punch to get it in trouble.
