10.3 JL body mounts
Lashlee
Knoxville
Does anyone know if the Axial 10.3 Jeep JL hidden body mounts will line up on the Enduro chassis? My wife has a 1:1 Rubicon and she has mentioned more than once why none of my crawlers have a JL body (one has the MST JP1,not close enough for her). If memory serves me, the chassis should be relatively close. I don't care to use the normal body posts, but hoped the hidden mounts would work on the Enduro chassis.
I tried searching the forum and don't see if anyone was able to use them.
Thanks in advance!
Not without modification. The rear body mount is integrated into the bumper mount, and the hole spacing on the mount is not the same as the spacing on the frame, so you'll need to do work on the mount to get it bolted up.
The front mount is part of the bumper, so that will work. The bumper mount from the 10 III will not fit at all.
Well nuts!!! I went ahead and got the parts on order so I guess I'll be playing the what fits where game to see if I can make it work! Thanks for the info!
I happen to have both an element 12.3 chassis and a JLU 10.3. I tried the body on there. The front mount lines up with front bumper mount of the element. The rear mount lines up with rear bumper mount.
To mount it using the JLU mounts, some sort of L-Tab is all that is needed. Either some bent plate metal or something 3D printed could work really well.
Thanks for the info!! I've also got a set of the Knight Customs 4-10 JL mounts printed from a buddy so I guess I'll try that first.
