BlackSeaRC
I have an application where I have two motors and two steering servos. I would like to use a pistol grip and wheel style transmitter to operate the vehicle as follows:
Mode 1: Trigger operates motor 1 only and wheel operates steering servo 1 only.
I want to flick a 2-position switch (or press a button) to change between Mode 1 and Mode 2.
Mode 2: Trigger operates motor 2 only and wheel operates steering servo 2 only. BUT, I also want motor 2 to rotate in the same direction for forward AND reverse.
I assume that I would need 2 ESC's connected to a receiver. Is it possible to set-up this functionality using a transmitter with mixing?
