#13 FJ60 is waiting on links so this gets an early start. A V4 G-Shot build but with, yet again, another Toyota body. I have already used this body before (#7 work truck), but this will be a different version. This will be a cheater rig but just no exposed front shock towers, and trying to keep the weight down on this one. Paint scheme will most likely be white with a white faced wheel. Not set quite yet.
The body work:
- Cab only (cut off bed)
- Cut headlights/grill/bumper off
- Trim wheel arches long like others do to hard body version
- Body 1" narrower to fit on sliders
- Cut top half off, move it forward and down for chopped top look
- Pro-Line 5" thin curved light bar (as headlights)
- Some custom single bar bumper to protect light bar
With the body being smaller in dimensions all around after those modifications, I'm hoping it'll all pan out nicely.
Parts list (few not in possession yet):
- V4 kit/White CF rails/white skid/TGH FMM mirrored/Creeper T mirrored/titanium spacers/GLD lay down servo mount (in case I decide to run 3 link)
- Wild Boar driveshafts
- G-Shot kit
- VP clear Currie Capra F/R axles
- Probuild wheels (standard width) or Spec RC tri spoke
- JConcepts Ruptures (3D inners or Halos)
- Gmade G-Transition 90mm shocks
- Overdose flush body mounts
- 3BRC G13 Pro servo/3BRC Yellowjacket/HH Crawlmaster V2/Radiolink 4ch Rx
Here are some beginning pics for now and I'll probably have to update this shortly.
Drew the lines where I'll make the cuts for the front end. Need to figure out the top half and down the middle still.
Here's the chassis with the FMM and T case in place. When I mirrored the skid mounting holes, I also moved them forward as much as I could just for more forward weight. Because of the angled skid and angled transfer case preset in the right hand side, I also hollowed out the skid a bit to make up for the extra opposite angle. DIY LCG mod if you will, since the T case now sits lower. And if the rear driveshaft binds at the skid, I'll shave more off the skid.
Here you can see the width difference.
The body work:
- G-Shot kit
