I’ve never owned one, but a lot of people have good luck with the RC4WD Warn winch, and at $35, might as well try it out. Is there any flat spot on that bumper? It comes with a mounting plate.
https://store.rc4wd.com/RC4WD-110-Warn-95cti-Winch_p_3734.html
RC4WD also has a winch controller for it, I don’t think it’s included with the winch though.
Everything @QuesoDelDiablo said!!Whatever you do, DON'T BUY TAHT RC4WD WINCH CONTROLLER!!!
It's bulky, not waterproof at all and they fail regularly. It's junk.
There's a vendor on here (HeyOK Performance) and he makes a $25 winch controller that's leaps and bounds better than the RC4WD junk; tiny, waterproof and reliable. He also makes another style that's a little bit more money but can run higher voltages so your winch will be faster and stronger. He also has a wireless option available as well if you don't have an extra on your Tx to run a winch.
As far as the winch itself, a good bet is the RC4WD Warn winch but the best bet (for a scale inch anyways) is the RC4WD scale 8274. The free spool option is mucho excellente to have when you need to spool out line for far away pull and it's crazy strong...
So I’m thinking about adding a winch and have no idea which one to get. Also I probably need a new bumper. What ideas do any of you have?
Another option for a winch is a servo winch with a 3D printed mount or homemade mount to fit in between the inner fenders. I've burn't up too many of the RC4WD winches, so I went with the 3Brothers Overlander winch. This winch mount is a 3D print from 3DtoRC on Thingiverse. It is an easy print and fits great!
Gonna throw a dumb question in here - - - is the second servo slot on the front of an Enduro frame for a servo winch, or is it just in case you want to switch the steering/panhard/all of that to the passenger side for some reason?
Not trying to thread Jack but I recently saw a picture where somebody transferred on their TRX4 the stock steering servo location to the front most position on a bumper mount with a servo mtGonna throw a dumb question in here - - - is the second servo slot on the front of an Enduro frame for a servo winch, or is it just in case you want to switch the steering/panhard/all of that to the passenger side for some reason?
*cool...Googles price of winch and controller...decides to pick up truck with his hands lol. I may do this eventually, it is intriguing but gotta buy like 8lbs of brass things first haha.
A 20kg continuous rotation servo can plug right into a spare receiver channel with no external controller needed, is strong enough to deadlift a 10+ lb truck and can be had with an aluminum winch spool for about $30.
It all depends on how big you want to go. The RC4WD winches provide a scale look, but I have not found one yet that I couldn't easily burn up. I like servo winches, I buy 25kg servos off of Amazon, strip the guts out of them and wire them up to a HW1060 ESC. The mount above is one that I designed (3DtoRC is my Thingiverse channel), and it works very well. There are a couple versions of this mount to fit your needs, or if you want something specific, let me know, I can see if I can't modify the design.
Another option is to go full-retard with it. I have also designed a winch using a 1/18 scale transmission that is an absolute beast. I am using this in my TRX6 (post #24), the base for this is also on my Thingiverse channel.
http://www.rccrawler.com/forum/traxxas-trx-4/612204-greatscotts-trx-6-a-2.html
Ahhh. I was under the impression it needed to be regulated due the creep and what not. Certainly is affordable if you go that route.
