MadmanRC
GT3B Dead after flash
Hi All (Hi Losikid),
I have flashed two GT3Bs and both work very well, I have a 3rd radio that I wanted to flash. I messed up flashing it as I flashed it with a blank file then assumed I had bricked the MCU so I cut it out and replaced it*. :x The new MCU is supposed to be the same as the old one. It accepts the hack firmware but does not turn on at all.
NOTES:
The radio has a smaller charging plug than the other 2 radios so it is different from the others - Are they ALL flashable with the same firmware ?
MCU
The original MCU that I cut out was a STM8S105K4T3 and the replacement is a STM8S105K4T3C the difference being the maximum ambient temperature it can handle, so they should be the same.
PROGRAMMER
When programming we are supposed to select the STM8S105x6 however the old and new chip is a ST8S105x4 - this, when selected gives errors.
SO, is it dead ?, can I get it going again ?, if it cannot work on the hack firmware can I put stock firmware back on - where can I download the stock firmware (Googled till my eyes popped out but could not find it)
*yes, I made very sure al the pins are soldered without solder bridges ;-)
Anyone with ANY help would be appreciated.
NOTES:
MCU
PROGRAMMER
