I was able to get everything installed and connected, ESC options set, radio calibrated, and a quick 20 minute test run in. First off, the ESC was a breeze to get setup and calibrated. The included program card is easy to use and even has all the options and values printed right on the case, no instructions needed. I made 2-3 changes as needed and calibrated it with my radio in less than 5 minutes. After 20 minutes of full throttle bashing, it wasn't even the slightest bit warm. Not a huge surprise given the fact that this is a 1/10 scale, 80amp ESC but very satisfying none the less.
The servo performed flawlessly as well. Plenty of torque whether crawling or going fast, centered itself without issue, and really just had a good overall feel. Plenty of tumbles and rough driving, so far so good.
As far as the total package goes, now that I have some quality electronics in the Jr., it's an absolute delight to drive. I'm actually really happy with the stock motor. Coupled with the Hobbywing ESC, it's very smooth at low speed, has plenty of wheelspeed for me and has enough torque to kick plenty of rocks and roost up behind itself as you lay into it. The truck handles very well and only traction rolls if you push it hard at full tilt. It's not difficult at all to drive the little Yeti at its limit but still keep things under control and the rubber side down on high traction concrete or asphalt. In the rocks and dirt it slides and drifts very satisfyingly. There's very little if any torque twist and the Jr. turns a very tight circle and is incredibly maneuverable at any speed. Like I said, I've only had around 20 quality minutes driving this truck but so far I'm very happy with my electronics choices and I'm definitely impressed with the chassis and suspension. I'm excited to get more time behind the wheel but things are looking good for my latest addition to the fleet.
Here's a pic of the receiver mounted on top of the servo and the ESC mounted on top of that. Everything nestled in there nicely and let me maintain a nice low CG. I'm very happy with the way everything came out and I can't wait to drive it more.
