monkeyracer
By the way, I managed to stuff a Zippy Flightmax 3S 45C 2000mah battery in the tray. The dimensions were 102mm x 36mm x 24mm, and is about as big as you can fit in the tray. It's a lot of weight up high though.
I haven't been able to run it, since I need to solder the right connectors for my Mamba Micro Pro, but I'll be sure to report back when I do.
Also, I mounted the Power HD 1711MG in, and it fits great. I'll let you guys know how it works out.
You might be able to fit a short standard servo in this if you really needed to.
