Hardline
2. Up to a certain shock angle from vertical--dictated by chassis design/link arrangment, your damping rate will be progressive.
I'm having trouble seeing that. The shock/spring has maximum leverage on the axle when vertical. "Progressive" means the rates increase with compression, agreed? Any angle of shock will increase with chassis compression therefore digressive. To become progressive the shock would have to stand straighter up with chassis compression. True, I'm thinking mostly of spring rate, but I don't see why damping rate would be any different.
Vertical gives the most shock stroke with chassis travel. Laid back gives less shock stroke for the same chassis travel. How can that be progressive?
It may have something to do with your use of "ride" travel which appears to be some horizontal component I'm not familiar with vs the vertical wheel travel I'm thinking of.
