tcanin00
This will be my first build thread on rccrawlers, although I have been a member since early April of this year. I have started a few discussions on build projects, and I have been reading other builds in order to get ideas and information from members of this forum.
I bought the TF2 kit just after I joined this forum. I had also just started an Active Duty job with the Pennsylvania National Guard so I had a consistent income and the time to build projects the way I wanted them to be, or so I thought. More on that later.
Onto to the build. Admittedly, I didn't take as many pictures as I should have to capture the build. With that said, here are the pics I did take.
First and foremost, the box:
Its amazing how many "unboxing" videos there are on youtube. I didn't film mine, just a picture:
I did watch videos of this truck in action, and decided to change the leaf springs before assembling the chassis. I used two sets of RC4WD 4 link kits for the front and rear.
Here are the upper link trusses on the axles:
The frame rails were already notched in front of and behind the crossmember for the hinge points of the 4 links. This made things much easier as I was ready to fabricate some form of bracket.
Here are the 4 links installed:
It was at this point I discovered why RC4WD only had a rear 4 link kit available. The upper links of the front hit the bottom of the transmission, severally limiting suspension up-travel. Rather than try to adapt the stock trans, or relocate it, I decided to cannibalize a different one that was intended for another build.
And it would be this one, an RC4WD R2 two speed with the ability to shift from 2WD to 4WD combined with a hand wound Tekin 35T motor:
The problem with this trans is that even though it has threaded holes that line up with the chassis of the TF2 and RC4WD does make a crossmember for it fit in the TF2, but it would not clear the hinge point brackets of the 4 links. Time to fabricate.
I made a crossmember that allowed me to mount the R2 vertically and clear the end links:
This solved the issue with suspension clearance. I wasn't able to use the kit supplied electronics plate or servo mounts, so I made my own:
The driveline angles are a bit steep coming out of the trans, but everything spins freely.
While changing things, I felt a set steel 1.9 beadlocks and Pro Line Flat Iron tires would work well for this truck:
Size comparison of the Flat Irons versus the 1.55 and Mud Slingers:
And the moment of truth, articulation:
Now to start the body work. I decided to drown out the molded yellow with primer:
After which I coated the body in import truck red. Then, after getting the idea from n00b's "Breaker-Breaker" I decided to cut out the hood and make hinges. It seemed like the best way to access the electronics and battery connection, rather than remove the body:
Here are the hinges being cut out of sheet styrene after many attempts:
Glued in place:
I then glued strips of styrene to the fenders and cowling to seal up the gaps:
Another articulation shot with the cab on:
The new hinges work perfectly:
I then painted the panel lines, cowling, and window trim:
After this, I clear coated everything:
Then I could start final assembly:
I also fitted a set of fender flares to match the added width of the new tires:
Here are how the electronics are situated under the hood. I was able to stand the 2S hard case Dynamite LiPo up vertically against the steering servo and use it to mount the ESC:
I swapped the kit front bumper for an SCX-10 Trail Honcho one:
Here is the rear view with Hilux decals and detail parts installed:
I decided to take some better pictures with my new phone which show some of the more recent changes.
Here it is with a Dingo bumper:
Top view:
More pics from different angles:
This one shows the Pro Line tool box and tool kit, and the Trail Honcho spare tire carrier:
Rear view:
This is where it stands as of now. Earlier I had mentioned thinking I had more time to work on this truck. What changed were my deployment orders to Kuwait. This will be my second tour, I was in Iraq in 2008. I do not plan to not take this truck with as shipping it with Army gear may a bit too much for it. I'll pick up on this project when I return.
Glued in place:
Top view:
Rear view:
