JeepinDoug
Hopefully I'll have weekly updates on this rig.
OTT means Over-The-Top if you don't figure it out by the end of this first post.
First up, VP wheels.
These were straight out of the package and into the machine, (bought from JPH, thanks Jake).
I didn't like the width or offset.
Machined from 1.200" width to 1.075" wide.
.125" deeper offset in the rear.
.069" deeper offset for the front.
A little extra weight taken from the core diameter.
Not pictured, is more I had to counter bore the inside face to clear the knuckles which did not change my offset.
Next up......axles!
These are not finished yet. Again, straight from CKRC and into the machine.
Fluted and shaved tubes.
Lightening holes for the gears.
So far 1.5 oz off each axle, weighed complete less hexes and pins.
For example;
Long tube bare weight
stock 121.5 grams
Mod'd 92.5 grams
Short tube bare weight
stock 68.0 grams
Mod'd 56.0 grams
Main gear
stock 11.3 grams
Mod'd 8.9 grams
I still have more work on these axles but now you probably understand the OTT.
Next up......axles!
For example;
stock 121.5 grams
Mod'd 92.5 grams
stock 68.0 grams
Mod'd 56.0 grams
Main gear
stock 11.3 grams
Mod'd 8.9 grams
