03-12-2009, 09:21 PM | #1 |
Servo choice?
I searched and found nothing. What servo are you running? Full Size or Mini? Why did you choose your specific servo? Thanks
Sponsored Links | |
03-12-2009, 09:24 PM | #2 |
I have the Hitec 5645MG (its digital). 166oz torque @ 6V. Has worked great and it comes with a aluminum arm, just have to drill out the hole to take the stock ball stud.
03-12-2009, 09:46 PM | #3 |
I just installed the Hi Tech 5245MG Digi Mini (ran it today for the first time actually). It's great, way better than stock and I prefer the smaller size in my DMG tube frame, I think the full size servo would look funny in there.
03-12-2009, 09:58 PM | #4 |
09 RCA champ!
im using a 645mg and it works ok i guess. ill probably eventually go with a 5955 or something similar....maybe a little overkill, but i like the extra power when its in a bind.
03-13-2009, 02:58 AM | #5 |
right now a 645mg becuase it was $30 and wouldn't strip out like the stock one. probably going to switch to a mg mini next though.
03-13-2009, 08:47 AM | #6 |
running a hobbico full-size servo...not sure which model but its equiv to a 645mg. the stock one is ok, but having a 645mg on a MRC is like having 400oz on a 2.2....its just so much nicer.
03-13-2009, 11:01 AM | #7 |
id say 645mg. No complaints on mine yet, its waaay stronger than the stock servo.
03-13-2009, 12:00 PM | #8 |
TN State Champ 11,12,13
Hitec 645. Lots more torque than the stock servo.
03-13-2009, 03:12 PM | #9 |
Hitec 645mg, works great on this little rig. I have even used one a 2.2 with good results (a little under powered on a 2.2 but didn't burn up or strip). I think anything more is overkill for this little rig.
03-15-2009, 04:21 PM | #10 |
I'm using a Hobbico "Super Torque BB MG" and it works great with my stock ESC, if found it in my spare parts box so I don't know where it came from or how much it costs. Remember you will need an aluminum servo horn or you will just strip out plastic ones.
03-16-2009, 07:57 AM | #11 |
I use the 645 because its much better than the stock, is fine to use with stock electronics, and I found its pretty easy to waterproof. And yes this is my losi mrc
03-16-2009, 08:59 AM | #12 |
I too am running a HS-654MG Hitec steering servo with good results.
The stock one is just to weak & wimpy. |
03-16-2009, 11:41 AM | #13 |
I ve tried the mg225,mg5245 and the 645,the 225 aint much better then stock, the 5245 noticable improvement, burned out when I starting adding weight to the rolling stock, 645, makes fitting a batt on the front axle a tight fit, but can be done with a small 2s2p setup,but well worth it and cheaper then the 5245,also tried and true servo for crawling, If I was gonna go another route I would prob slap in a Toward pro mgr946 from JPcustoms, 180oz for $18 ,metal gear too, doing well in my cr01
03-16-2009, 06:47 PM | #14 |
I'm running the digital Hiec 5645MG. It's full size and plenty powerful.
03-16-2009, 10:05 PM | #15 |
I just got a 645. running pretty well. i even got it mounted on the stock servo plate.uses strong mounting tape and have only one screw on any one else have a better idea other then getting a full size servo plate?
03-16-2009, 10:10 PM | #16 |
645...works great once i got it mounted solidly.
03-16-2009, 11:33 PM | #17 |
Cut up a piece of lexan and use the top two holes in the stock servo posts. Thats what I have for mine, think its 3/32" or an 1/8" and no flex at all...besides the steering linkage.
