02-07-2009, 10:17 PM | #1 |
09 RCA champ!
Red's KK 4.0 Berg build...
ive had this done a for a couple weeks now and thought id post a few picsim still fine tuning it to my liking, but over all i LOVE itparts list...
KK 4.0 chassis and skid KK high clearance delrin links KK steering KK dig tray 55t V10's Mamba Max CC bec Hitec 5955 servo Hites hs55 dig servo Mayhem 7's berg offset (ive also got a black set that will be on soon) HB Rovers Losi Crawler shocks w/traxxas rod ends hong kong 3 cell home made battery tray ive made a couple small changes since the pics above...mainly clocked the front axle and lowered it a little. i had a shaft slide out at the last comp and screwed up my locker. ive got the new locker, but im still waiting on CKRC's rear straight axle kit more pics to come... Last edited by rednck21; 03-14-2009 at 06:40 PM. |
Sponsored Links | |
02-07-2009, 10:30 PM | #2 |
had the same problem with my locker, i put a small ring(1/16in) of fuel tube between the outter and inner shaft and it took up the slop
02-07-2009, 10:38 PM | #3 |
Does anyone have pics of what are you talking about ? i'm in the middle of a build, i've installed a straight axle in the rear, do i still need to address a potential problem ?
02-07-2009, 10:40 PM | #4 |
WOOPOOW!!
HUUURRRR HURRRRRR!!!!!!!! I beat you in a drag race!!!
Truck looks really good man! How did you get yours so clean? I seem to be suffering from a bad case of crappy electronic placement :-( |
02-07-2009, 10:41 PM | #5 |
09 RCA champ!
i think your ok if you have the straight axles. i swapped the axial stubs over and thought i didnt need the o rings. wrong! the o rings in the cups should take care of the problem. that reminds me...ive still got to put them in the front
02-07-2009, 10:42 PM | #6 | |
09 RCA champ!
Quote:
those dang 45t's i like my wiring to be cleancant stand a rats nest... |
02-07-2009, 10:46 PM | #7 |
WOOPOOW!!
02-10-2009, 12:14 PM | #8 |
09 RCA champ!
finally got the rear back together. this CKRC lockout kit is very nice! it shaved .7 oz of weight off the rear end. the only problem i ran into was i had to shorten the short side shaft about 1/16". other than that minor problem its a great kit!
02-24-2009, 09:23 PM | #9 |
09 RCA champ!
i managed to get a 2nd and 3rd place finish at the first two RCA comps this year im really liking this whole berg fad...hopefully it will last awhile
most of the parts are in the mail for another Zero T build, so stay tuned..... |
02-25-2009, 05:33 AM | #10 |
nice crawler blaine, im building a berg right now allmost the exact same as yours
02-25-2009, 10:16 AM | #11 |
Looks good. Truck is working great. If you can find some Berg ball ends they fit in the Losi shocks so their is no need for fuel tubing.
How do you like the panthers vs rovers?? |
02-25-2009, 04:13 PM | #12 |
What is the belly clearance on your set up?
02-25-2009, 07:11 PM | #13 | ||
09 RCA champ!
Quote:
Quote:
as for the tires....the rovers seem to have a little more forward bite than the panthers...especially on med. to low traction surfaces. the rovers dont side hill as well as the panthers do. the lack of sidehill ability cost me a gate at the last comp:neutral:im still playing with the foams on the panthers though... 3" with the panthers and 3 1/8" with the rovers. |
02-28-2009, 10:19 PM | #14 |
What length uppers are you running?
03-01-2009, 08:23 AM | #15 |
09 RCA champ!
03-01-2009, 02:53 PM | #16 |
rig looks great, how much narrower is your rear axle with the CKRC lockouts?
03-14-2009, 06:30 PM | #17 |
09 RCA champ!
03-14-2009, 07:16 PM | #18 |
03-14-2009, 08:31 PM | #19 |
09 RCA champ!
it helps with the axle swing. maybe someone can explain it a little better??
03-15-2009, 06:14 AM | #20 |
