Zuke revamped to C3/trail rig
distinctive pd
Subscribed Member
Utah
I just wasnt happy with the performance of this chassis under the Zuke for C2 so I figured I would see how it does for C3... threw some professional grade Flat Black on the chassis after i sandblasted it. Also will be painting the body and panels Bright Red!
Original build thread: http://www.rccrawler.com/forum/1-9-scale-rigs/543069-dp-built-c2-lwb-zuke.html
Samurai hardbody with styrene bedsides
Finished tube work
Added new winch mount
Finished interior roll bar
Brazed nuts in for potential 3d interior
Built AR60s w/Bomber knuckles, HD gears Dlux and VP trusses
Built Wraith trans
Rc Bros Eggressor delrin shocks 95mm R / 85mm F.. super soft springs
Yeti drive shafts
Elect... TBD
WHEELS AND TIRES... TBD
file.php
file.php
file.php
PAINTED AND READY FOR ASSEMBLY
file.php
file.php
Axles mounted up with Dlux truss and bomber knuckles.
First coat of Red paint
file.php
file.php
file.php
file.php
file.php
file.php
file.php
Winch mount is in! Most details done ready for
Electronics and wheels and tires!
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
Almost complete. ..and thanx to my pal Low Budget these wheels and tires are just what the Zuke needed!!
OG Locked Up 8L alum beadlock wheels w/ some nicely scrubbed R35 Ripsaws!
Electronics and interior next!!!
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
file.php
IMO it needs the rocker panels trimmed up a bit to add some clearance, basically making the boatsides about a 15*angle from the chassis to the body, it will be getting a SMW skidplate, Ti links, and might carefully remove some tube to lighten it up a bit, beef up the axles and then we will see what happens.
It is going to be mental torture removing some tubing considering the time and skill that distinctive put into it.8)
I hear ya on the mental torture part.. I don't wanna change a damn thing on my new to me xj.
What's the reason behind flipping the rear axle?
The build looks great! Can't wait to see more progress.
You're torturing me with with your Caddie too.
I believe it's because he had a front VP truss/ULM that was on the rear and the rear driveshaft would not work if the axle was the standard set up, pumpkin on driver side.
The rig is completely torn apart as of now and will be getting a rebuild with my own touch of stupidity or ingenuity.:ror:
It has been my experience that along with the rest of the rig setup right for crawling. . ..flipping the rear axle to opposite side of tranny output also "helps" eliminate torque twist as long as there is no binding in the drive shaft. That is the gist of it anyway. "thumbsup"
Did you pull that answer out of your shrubbery? NE!
