I'd been wanting an rc forklift for a pretty long while. Years ago many of the great 1/14 scale modelers around built some, and made Warehouses and Loading Docks to go along with their Semis.
However even the Carson Linde h40 is more than i want to spend to get one here. Do i really need one... Fork yeah!
I had picked up a static Bruder Linde H30 a while back, but it's been pretty slow to plan out converting all the lift functions to rc. Then with so much time spent watching Loading Wars / Loading Kings it looks like even more fun.
To save some conversion work, I picked up the NewRay Yale with pallet rack and some cargo. I sometimes run Yales at work, and it's a little bigger thar the Linde so i should have some room to work. It's based on something in the Yale Veracitor VX series, think looks really close to the VX50 to VX70s. I dunno, it's not the original run of these with Yale licensed livery and labels
They come set up as 3 channel binary control, runs on 3aa batterys, 9v in the tx. Not that impressive, but still kinda fun. I can see why the old reviews on these weren't great when they were still yellow and Yale branded. It had weak steering one direction, then it gave out within a week of getting it. Wasn't planning to upgrade until after the Lebanon IN meet, but it changed those plans. Nothing too crazy to start with because rush job, just parts i had on hand. 6ch rx, metal gear servo, 2 cheap escs, a blinky rotator light, some 3mm leds, 4aa rx pack.
I went back to look again at the several rc sparks videos of upgrading the Carson h40 Linde they run on the Loading stuff and went "similar but different".
https://youtu.be/JSBuD7sZwV8
https://youtu.be/QsLQpNzo_EI
One really nice thing about these Newray vs the Carson forks is the mast lift has retract springs instead of working on gravity, so i don't need to add weight to the fork rack that would take away from how much weight it can lift and still steer with a load on.
The small cheap no-name brushed escs are a good fit, as it's only pushing 130 motors. Steering servo took a setup i wasn't fully happy with and will probably change if i made another, but it kept it all below the battery rack and might even get me some high speed wobble.
I used a flysky "fs-x6b" rx, and it just happens that board uses the same mount spacing as some posts in the forklift. I don't actually reccomend it since you basically have to make power and ground bus and connect individual signal wires to evrything. I like plug&play rx options better.
Battery lives up in the forklifts counterweight, i knocked out the seperators and forward wall to shove battery through. Also hogged out the battery cover stiffeners a little so i wouldn't need to worry about pinching a wire. Stuck some micro JST connectors on because they look pretty similar to scaled down Anderson PowerPoles.
Had to put a yellow beacon on the ROPS... Safety Third.
It's not right to ever try to be a spotter for a forklift without having lights shining directly in your eyes, so i drilled out the square housings for some 3mm leds with some chrome paint, all wiring routed down a channel in the ROPS and tapped the yellow beacons harness for power with a resistor. White lights & beacon come on when model turned on.
It takes 3 screws to split the body off the chassis, and now disconnecting Light and Battery connectors to completely remove it.
Dropped a bruder figure in the seat, probably needs a seatbelt.
It's got a cup holder on the bulkhead, so i opened that up and shaved the bottom of a dollhouse coke bottle. Had to pop the cap and drill the mouth of the bottle.
Think i'm probably going to need to come up with some decals for this after i paint the black parts. Could use some weathering.
Later i'll set up another servo for rack tilt, and start working out how much ballast i'll need.
I'd thought about trying to go moving steering wheel, but don't think there's enough room to keep it looking right. I'd either have to lose the steering column, or put a bulky box on the bulkhead.
Still looks pretty similar to stock, wish i had the yellow Yale version, but i think i've got a pretty good plan for a company livery based off the orange-red
I should have screwed on the battery cover, but i was in a hurry with those pics
