Hi All.
Thought I would post up my WJ Grand Cherokee build here for you all.
As a bit of background, I was the first to buy one of these from a local seller here in Sydney Australia, and from there shared the find on Scale Builders Guild. Now there are a few getting around thought some of you might be interested in seeing how my turned out.
I won't start from the very beginning but this will get all the important bits.
I have been doing some research on the WJ Grand Cherokee.
The wheel arches on this body are not standard spec wheel arches.
They do however, closely resemble an aftermarket flare option available for 1:1 rigs.
And this of course meant that a stock spec build was no longer a viable option.
So a trail worthy/overlander spec rig is now the new target.
Like all good scale builders, I have a "small" pile of used scale tyres and recently picked up some 1.7 wagon wheels.
I mounted some 1.55 Pitbull Growlers on the 1.7s and liked the result.
More of that later.
Before I started on mounting the body I relocated the rear shocks using SCX10 Shock hoops and some holey alloy I had previously made. The original shock hoops will be right where the rear seat needs to be so will be fed to the dremel.
Then of course the front also needed to be lowered, so I removed the 90mm dual springs, and installed a single 110mm spring onto the 90mm shock creating a semi droop configuration.
I had to adjust the panhard bar to suit of course.
I thought long and hard on how to mount the body on the chassis.
I had a couple of requirements to work within.
1. no visible bolts
2. needs to be secure - I wheel my rigs, no shelf queens here
3. won't be removed very often
In the end I came up with this. I started at the rear.
Some alloy brackets and a piece of 2mm Styrene. A careful observer will note the curved outer edge of the sytrene.
I applied a similar idea to the front. This time bolting under the servo.
The first test fit of the body went pretty well. You have to stretch the body to get the front bumper over the front mount.
Two things were immediately obvious.
The wheel base needs adjusting.
And the rear is too high.
I removed the alloy plate and bolted the top of the shock to the hoop itself, lowering the rear ride height.
I went ahead and mounted my 1.55 growlers on the other 1.7 wagon wheels.
This is the current stance. I like this a lot and certainly has the feel of a modified street driven trail/overland rig.
The rear of the body is a good 10mm wider than the front.
The skid plate is near even with the sills, and the lower links have a nice flat profile.
There is heaps of room inside for the interior.
And the front motor mount and transmission is tucked nicely under the front bonnet (hood).
There is more to be done with the body mounts to secure the body to the mount. It currently slides a bit left and right.
Cheers
H2Micr0
More of that later.
1. no visible bolts
Cheers
H2Micr0
