Wireless Winch, Light and Two Position Servo Controller
heyok
Vancouver, BC
Now you can work lots of things without using up any extra channels on your transmitter.
This wireless controller will run a winch, lights and a two position servo.
There are two versions. One with a servo winch and one without.
The double deans style plug (or if you ask, you can have a double XT60 plug) allows you to plug this controller in between your ESC and battery so that you don't need to solder this connection.
The servo style plug is for servo power. This can be from 5 volts to 9 volts - you decide - and match it to your servo's power needs.
The two small rotary controls are potentiometers that are used to set the two servo positions. Push button C on the remote fob to moves the servo from one position to the other.
With a servo winch Part number: WWALLS $115
Without a servo winch Part number: WWALL $90
