heyok
Winch Controller for Radio with 2 Position Third Channel - Part no. 2PW
What do you do if you want to run a winch but your transmitter only has a two position third channel?
My new winch controller makes this easy. Just attach it to your servo winch motor or to your 3racing winch and you will be able to work it from your third channel. Each time you press and release the switch on CH3, the winch does the next thing in sequence.
Note that this controller has the optional JST connector which adds $2 to the price.
Here is a very short video showing the circuit controlling a winch plugged into a Traxxas TQ3 transmitter which comes with a two position third channel:
Winch Controller for two position channel transmitter - YouTube
This winch controller installs the same way as my winch controller circuit that works with a three position channel:
No Drift Winch Controller! (using 3 position transmitter channel) - RCCrawler
Part no. 2PW $30
Need a JST connector included? Order Part No. 3PWJST for $32
* Note that the maximum voltage is 6 volts *
Need to make a servo winch?
http://www.rccrawler.com/forum/electronics/421321-another-servo-winch-building-tutorial.html
- Winch is stopped
- Winch winds out
- Winch is stopped
- Winch winds in
- Winch is stopped
Part no. 2PW $30
