mrluckies
I have a Losi LMT, but this will apply to a lot of other trucks and crawlers. How do you know when you have a strong enough, but not too strong servo saver?
I broke a few servos on the lmt and finally bought a reefrc raw 500 for it. I also bought a treal servo saver. It comes with a standard and harder spring. Plus you can tighten the nut a couple turns to increase the tension.
So how do I know if I need the standard or higher tension spring? And how do I know when the spring tension nut is tight enough?
If the spring tension is too loose, it won’t protect the servo because it will immediately go to the end of travel and the. Transfer tha force to the servo.
If it’s too tight, it’s like not having a servo saver at all.
Any suggestions?
Any suggestions?
