You basically need a front axle in the rear.
C-hubs, knuckles, universal axles (or dog-bone set-up) a pair of 10x15x4mm bearings, a second servo, servo screws (4), servo horn, servo plate, servo mounts, servo extension/Y-harness (maybe), steering linkage, rod ends, pivot balls, flange pipe (4), screws to secure the knuckles to the C-hubs (4) and other miscellaneous hardware needed to complete conversion.
Double check your manual for part numbers and to compare the differences between the front a rear axle diagrams, there may be something I've missed.
I prefer the Wraith servo screws.
The Y-harness is for running both servos off the same channel on the receiver, the servo extension is for running the rear servo off the 3rd channel.
