Welcome to RCCrawler Forums.
Just wondering how strong Twin/Mad Force axles are? Would the hold up to bashing Jumbo Kongs? Can the be built to handle big tires like Kongs? I am looking to build a monster! And the Kongs are the tires I want to run. Thanks for your help!
They would be the best bet for Kongs by far. If you are using dogbones, just be sure to put rubber O-rings inside the drive cups to keep them centered so you don't bend shafts.
JohnRobHolmes I am not sure how I will run if Dogbones happened to be the strongest option then that will be what I run so I will keep that in mind!
Binaryterror I have been checking out SuperShafty already, I like to do my research before I get into anything. That's the reason I am gathering info on the Mad/Twin axles, Clod axles don't really have the look that I want. All the sites I have found have some pretty neat stuff no matter what you build!
To have a stronger option than dog bones most convert to CV shafts. It my "Sticky" there are many options available for direct replacement or custom widths.
