TITANIUM94010
I'm going to be making a full brazed metal roll cage for my Prerunner, my question is do I use 3/16 tube or 3/16 solid rod for a roll cage /chassis?
Ive looked around, some guys say tubing is strong enough, others say that it'll dent the first time you drop your rig.
The cage I'm making isn't very structural, as the chassis is still held up mainly by scx10ii C channels, but the cage will still take a lot of impact. (I may end up brazing the cage to the chassis later)
It would be preferable to keep the cage on the lighter side, but I'm willing to take a few extra pounds to avoid from it being destroyed in a large crash.
I am going to be reguarly hitting 15-20+mph so it does still need to be strong.
If I have to go with solid rod, would welded stainless tube be stronger than solid mild steel? I would prefer to go with brazing, but if there is a drastic difference in strength between welded tube and brazed rod, then I may consider switching.
Also, where do you guys get your tubing/rod from? For a different project, I got a 3/16 brake line from an automotive store, but it was pretty overpriced for a few feet.
Thanks!
Thanks!
