I installed the Traxxas low range (crawl) gears (# 9776R) in my High Trail because it was too fast and jumpy in stock form. After the installation of these gears, it was dog slow. So I then installed the Holmes Hobbies 66T motor. It is better, but still lacking a little speed for my liking. I know, I know. I'm never happy! Since the installation of these parts, there are a ton of new motor options on the market.
The most intriguing to me is the Traxxas # 6250 because it looks to have a super smooth and silent start-up and is a plug-and-play drop-in. Does anybody have this brushless setup installed along with the #9776R Low Range gears?
I could also just change my motor to the Injora 48T, 55T or Meus 44T. Do any of you have experience with these motors along with the Traxxas Low Range Crawler gears?
There are two-speed transmissions and I don't really want to add that complexity and weight to this truck.
You can even get the Injora 370 size motor and transmission, but I'm not really interested in doing that.
Any other options you would suggest?
Current System
Traxxas Low Range Crawl Gears #9776R: Gear set, transmission, low range (crawl) (40.3:1 reduction ratio)/ pinion gear, 11-tooth | Traxxas
Holmes Hobbies TorqueMaster Sport Mini 180 66T motor: TorqueMaster Mini 180 size 66t for TRX-4M
Brushless Options
Traxxas Brushless Power System 3350KV #6250: TRX-4M® Brushless Power System, waterproof (includes ECM Brushless electronic control module (3-channel) and 3350Kv brushless motor) | Traxxas
Injora Purple Viper 2800KV #1721 : INJORA Purple Viper 1721 Brushless Motor for 1/18 TRX4M Ascent-18
Brushed Options
Injora 48T: INJORA 180 PRO Brushed 48T Purple Motor with Steel Pinion for 1/18 TRX4M (INM11-48T)
Injora 55T: INJORA 180 Brushed 55T Red Motor with Steel Pinion for 1/18 TRX4M (INM11-55T)
Meus 44T: MEUS Racing 180 Brushed Motor Double Ball Bearing Motor with Brass 11T
Current System
Brushless Options
Brushed Options
