CrawlinMike
Been awhile since I’ve posted on here and don’t see too many lowered to look like a stock truck.
Here I’ve taken off the rear shock towers and put a defender tower on the front. Rear shocks to frame I think are 24mm and front 39 eye to eye. As it sits it is not full droop and can compress and extend from the static position. I didn’t want to be cheating by getting it that low by bottoming it out. Popped an interior in as well Holmes 66t, crawl trans ratio, 9% overdrive, metal servo gears, and I’m awaiting parts in the mail to make a sway bar. One other note is when you lower it you’ll need slightly shorter rear links to center up the axle to the wheelwells. It’s hooked up to run the traxxas trailer utility lights and pull that and I’m in the process of making a gooseneck. Pulling anything the torque twist is pretty amplified and well a sway bar will help out. It is already all bearings. Bed is painted flat black to look like liner and the body inside is now painted all black to prevent light bleeding through. Hope these pics work. The first pics are the up to date ones.
Don’t hesitate to ask anything as I can go into more detail or show any specific parts if you want.
