Now I know it isn’t strictly a crawler as such but thought I’d ask here on the offchance…
I recently picked up a used but stock Traxxas Summit.
Tested it on some partly charged 2s packs and it appeared to either cut out (lost throttle but retained steering) or go into a limp or half power mode.
I assumed this was the LVC cutting in and so fully charged the same packs and tried again. Problem still present.
Tried some different packs, problem still persists, albeit not as bad.
Having researched this, wondered whether it was the stock LVC cutting in and so switched the ESC over to nimh mode and the problem goes away. Ran fine for 5 mins, varying throttle positions etc making me sure it’s the ‘stock’ LVC halting play.
I know I could switch out the ESC to another aftermarket one with an adjustable LVC, or run a pair of external low voltage alarms but I’m certain it shouldn’t run like this in it’s stock formation.
Does anyone have any experience within this or could suggest anything to try?
Thanks
Thanks
