Tommy R
I loved my TT02-FRD, but when I saw the new TT02-RWD come out with the direct steering setup and easily adjustable gearing, it intrigued me enough to pick one up. I removed all the electronics from my FRD, sold it to a friend, and installed everything into the RWD when it showed up a couple days ago.
So before I went to install the electronics, I inspected the chassis to see how the fit/finish compared to my FRD. My FRD had several issues in the suspension.....namely loads of bind in the suspension arms and pretty terrible (negative) Ackerman. So first things first, I removed the shocks from the RWD and lifted the suspension arms. If there's no bind, the arms will easily fall down and to full droop. Nope. They stayed up. So I started looking into what was binding. Like my FRD, the issues are numerous. Some of the ball cups/ball studs are binding and the hinge pins don't move freely so it'll take quite a bit of time and effort to get them up to standard. But you don't expect a "fully optioned" carbon/aluminum drifter for $250 that won't have fit/finish issues.
The steering rack seems to move freely, but the problem there is the Ackerman again. In this case, the stock Ackerman will allow the inside tire to "over rotate" into a bind. Sure, you can adjust your endpoints on the servo, but that's not sufficient because sometimes this "over rotation" can be caused be a slight bump from a wall or other car. It really needs some sort of hard stop to prevent this. It's also got a bit too much Ackerman so maybe if I can adjust that a bit, the "over rotation" issue will resolve itself.
So here it is with the electronics installed. Keep in mind I've made no effort yet to clean up the wiring until I determine my final electronics layout.
- Speed Passion Reventon R ESC
- Speed Passion 10.5 motor
- Savox 1252 Ultra Speed servo
- GForce GC301 gyro (so I can control it via my transmitter)
- 5000 mah 2s hardcase LiPo
- And a V3 light kit
I also didn't even try the stock shocks. Instead I installed my TRFs that I ran on the FRD. Shock oil is about 27.5 front and 15 rear. Rear weight bias as shown is 54%. That's more than I'll likely want, but I want to try it like this before I start making changes. I also ended up running the Eagle springs because they were the only ones soft enough to get a reasonable ride height! All others would top out the suspension.
Over the weekend I had a chance to try it out on polished concrete. Overall, it performed pretty well, but there are some issues... The steering "over rotation" was definitely an issue despite conservative settings for the endpoints. The steering would bind and I needed to manually pop it free. The car's rear weight bias made it a bit challenging on occasion because of the pendulum effect of all that weight in the rear. In a drift if I would let off the throttle, the car was likely to either over-rotate and spin or it would square up and straighten. In contrast my FRD had more of a tendency to continue sliding pretty predictably. I'm hoping more front weight bias will help. I'm also hoping that reworking all of the suspension joints will free it up and help it work better. I improved it before running it, but it still has a long way to go!
That's it for now. Hopefully we'll have another test and tune session soon and I can try out a few new ideas....
