Panther6834
Calling all RC gearing & tire "math gurus"...you assistance is requested/needed.
PROBLEM: "Percentage smaller of front tire compared to rear tire"...or, "Percentage larger of rear tire compared to front tire" ???
I know that some reading the above statement are going to want to say, "It's the same thing"...but, you'd be incorrect. Yes, they *sound* like they're the same, just worded differently...but, in truth, they are COMPLETELY different. For example, you could say that 25% less then 100 is 75, and you'd be correct...but, 25% more than 75 is NOT 100 (it's 93.75, for those who might be wondering). So...what does this have to do with anything?
I have an 'interesting' project in mind, to be built using a crawler chassis, and solid axles (already purchased)...but, the 'plan' is to run larger tires in the rear. For example, the Arrma Felony (a vehicle I'm sure many reading this are familiar with) uses 100mm diameter tires in the front, and 107mm diameter tires in the rear...however, because of the ring & pinion OD to the front (Front 42T/15T, Rear 45T/14T), neither tire is "dragging" during vehicle movement. I don't know that the front OD percentages is...but, to put it another way, as OD is, the rotational speed on the front is just slightly faster than the rear, so as to 'compensate' for distance traveled during vehicle movement, due to the difference in front vs rear tire diameter.
I want to do something similar...except that I'll be using a crawler chassis & solid axles. The 'dilemma' I have is how to "refer" to the percentage difference, so as to help me determine what diameter tires to get. In other words, I need to know which "phrasing" is correct. As mentioned near the beginning, "percent smaller" is not the same as "percent larger"...but, I don't know *which* I need to be using in order to determine the proper tire sizes.
This is where I really need help from those more intelligent than I am in this area. I completely understand that, for this calculation, it's not the tires diameters that matter, but tire circumferences, as THAT'S where the percentage difference is important.
Here's what this all boils down to. Let's say, for example, the gearing I used gave the front a 12% OD. In regards to tire circumferences, would I need a front tire that has a circumference that's 12% shorter then the rear tire's circumference? Or, would I need a rear tire that has a circumference that's 12% longer then the front tire's circumference? One of these two is correct...but, I don't know *which* one.
To all the RC "math gurus", which is 'correct'?
