Hey guys,
This thread will be for the build up of a 'copy' of SlinkySams TINY build from 2007. Ever since I had seen that buggy built it was always stuck in the back of my mind. Sure, other people have built moon buggies, small, lightweight rigs. Nothing seemed to do what TINY had done. To me, the buggy had changed the game. Rigs were built different after that. Back in 2007 it seemed like using a 2wd buggy trans was obsurd when eveyrone was using Stampede trans. Therefore, my build won't be an exact to the T type build; namely because I want to build the rig to suit me and the more 'modern' things being used today. I will also be building the rig with 3/16 brake line and brazing it vs. solid rod as I don't have access to a welder.
Chassis:
3/16 Brake line
Solid rod for reinforcement
Brazed
Suspension:
Proline power stroke shocks
VP shock mounts in the rear
Custom built panard bar mount or a HandBros mount
Tamiya link mounts mounted vertical to the outlining skid
Rims/Tires:
1.9 Axial Walker Evans Rims
1.9 Proline Flat Irons
1.9 Rc4wd Rock Crushers
Body:
RCP threaded fab tabs to mount up the siding.
I'm not sure if I will go with Lexan or Styrene panels.
Lexan I could easily trace, mount, and paint them.
Styrene would be easily done with a template and could allow me to mount tabs on the 'inside' for shelving ie: esc mount, velcro for batteries.
Drivetrain:
MIP X-Duty Spline female in the front
MIP Summit Spline in the front
MIP X-Duty Splines in the rear
Front Axle:
Axial CVDS
Axial High steer Knuckles
Axial HD locker
Rear Axle:
Axial Straight axles
Axial Straight lockouts
Axial HD locker
Electronics:
LRP brushless crawler esc
Airtronics 94780m servo
Airtronics RDS8000 crawler radio
2s Reedy 1600mah lipos
In the event I run light bar or leds for taillights etc I will use a smaller Reedy lipo for lights/accessories
Miscellaneous:
Axial 'Recaro' seat
Proline Optima battery
SS hardware throughout
I grabbed these pics from SlinkySams thread so you guys can see the original build up of the rig.
Head over here for the original build as well:
http://www.rccrawler.com/forum/tamiya-tlt-crawlers/75858-project-tiny.html
*credit to SlinkySam for the pictures*
Now onto the build itself:
So starting off, I wasn't sure if I would have a build thread for the little terror, half way through I started to take pictures.
Link mounts throughout the rig will be Tamiya from the TLT-1.
The 'main' panard bar is to high. I'll have updated pics of its new(lower) location.
The trans will sit a bit higher, thus allowing room for the motor mount, spacer, and motor itself to clear the cross brace.
Side view before I started to clean up some of the joints.
Chassis:
3/16 Brake line
Brazed
Suspension:
Rims/Tires:
Body:
Drivetrain:
Front Axle:
Axial CVDS
Axial HD locker
Rear Axle:
Axial HD locker
Electronics:
Miscellaneous:
Axial 'Recaro' seat
