Welcome to RCCrawler Forums.
I'm curious what figurine people are using as a scale driver for inside their tf2s. I just picked up a 4runner and wanted to put a driver in it. Looks like the one rc4wd sells is about 6" tall. What are you guys using?
If memory serves me correctly. I used a han solo that was around 5-6 inches tall. But he got leg surgery with my dermal to make him fit. Still looks good though.
I thought I would revive this thread, as I picked up my first TF2 last week (the red 4Runner).
I have a NECA Marty McFly ready to go in it. However, I'll need to mod the seat or Marty, as it's a very tight fit to get him behind the wheel.
I'd rather not cut him up - I heard RC Review on YT mention melting the seat to get his Marty settled in the Hilux Xtra cab interior - but hs didn't show how it was done.
I'm assuming a heat gun would soften it up - I don't have one but I have a little gas powered heat shrink tool form my wiring. I'm thinking trying it with that.
Has anyone tried this melting method on an RC4WD interior?
I’ve done it on a Blazer body with a hot work station. It was easy enough, I went with a less is more approach and it took a while. I did have some tidy up with a dremel afterwards as it wasn’t a spectacular first attempt but I got there. The tricky bit was that the plastic isn’t even across the seat and some areas needed more heat than others.
I got there in the end and now my Neca Cassidy is in without being chopped and you can’t see the carnage underneath him. If I do it again I’m sure it’ll be easier now I’ve got some experience.
yer welcome, good luck. I’d apply the heat to the thickest parts first as they’ll take more effort and it may be worth using something like the butt of a hammer handle(best idea with limited thinking) to put more force on rather than use the figure.
