Joshwaa
I have the RX4 Roc412 3100kv combo. Can not get the truck (VS4-10) to go slow. It will jump around a bit then take off. I have the sensor wire attached and good connections on A B C posts. Tried messing around in the hotwire 3.0 app but still can not get it figured out. Is there a way to test if the sensor wire is working? I tried the method online where you turn the motor and the red leds should flash on the RX4 but that does not work. Any ideas?
