Hello,
I am trying to figure out an issue with my ROC412 3100KV with RX4. The setup is in my Element Enduro running a 16t pinion. According to my admittedly inexperienced math I should be around 53:1 final drive ratio. Now for the kicker, I am running this setup on 4s. I did this after a bit of research (supposedly startup speed should be the same regardless of voltage per Holmes) and after seeing Ty run his VS4-10 with the same electronics setup. In his video from the Tekin builds series his truck is substantially slower/smoother than mine(I have no idea what the VS4-10 gearing is.) I figured it was a programming issue and borrowed my brothers Hotwire to check it out, and was unable to find anything wrong, minimum throttle was set to 0, timing set to 0, I even added expo. At this point I am kind of ready to go out and buy a Mamba X as I suspect this is an ESC issue not a motor issue. I figure before I do that I would see if anyone on here had any ideas. For reference the build thread for the truck can be found here.
