Tekin ROC 412 rolling back!
Jamifra
Puerto Rico
hello!
got a 3100kv Tekin ROC 412 paired with a Castle MMP ESC. when crawling and coming to a stop in a hill and going again to forward it doesnt go forward and the rig rolls backwards and when it stops then it goes forward. anyone has experienced this and any fix for this? tha ks in advance!
What are your ESC settings?
My ROC412 and MMX didn't play well together until the firmware update. There was lots of cogging. But I never experienced this issue.
Is this a new setup and it never did this before? If it's new you probably just need to adjust your brake settings.
Sent from my Nexus 6P using Tapatalk
its a new setup
i can recall that its in 213% crawler mode
but have to double check the drag brake
drag brake : 213%
brake amount: 50%
start power: low
punch control: 70%
sensorless timing: high
Is your ESC set to FWD/REV (Crawler) mode? You need it set in the instant reverse mode.
Reseve Type: with Reverse
where is the forward crawler mode?
Top setting , look for fwd/rev
(Not the red square in this picture, but above it) this is set to proportional reverse lockout, crawler is forward /reverse
Hang up and Drive
Hang up and Drive
seems like we have different version of the castle link software.
Turn start power to high.
Make sure sensor wire is plugged in.
Set to sensored only or smartsense.
Sensorless timing should be low.
I think we need a video of what you're describing. Can you take one?
