Team Brood Scaler Limited Edition 35 Turn HVW 2015 #1
EddieO
Arlington, Washington
Found some more cool OG teardowns to make some limiteds with....found 6!
Built with a striking cobalt blue finish, the 1.4mm thick can features FB9 magnets. The full copper endbell hardware with massive aluminum heatsinks allowed these to run cooler than other motors. Curved solder posts, polarized spring system and cap screws allowed for a very compact setup.
The armature is a 35t double high-variance split wind, where one big wire is wound with one small one. These winds are very efficient on the lower end of the power curve and spool-up very quick to provide that horsepower when needed. Extremely difficult to wind, they will not be produced as a regular production item.
Armatures are dyed to prevent rust and drill balanced.
Only 6 Motors are being made...6 lucky scalers...
Shaft is engraved with wind.
Limited Edition Sticker
Here are the specs
2 Magnet High Torque Can
729 Standup Brushes
5mm Armature
Drill Balanced
7.5mm Comm
35 Turns High Variance Wind
Team Brood Racing :: Crawler Motors :: Handwound Motors :: Team Brood Scaler Limited Edition 35 Turn HVW 2015 #1
