nightcrawler48
I'm thinking of starting a Wraith project a little bit out of the ordinary. I'm at the parts to use list stage only and I was thinking of Super Swamper 2.2s for the rear and 1.9 XLs for the front. Haven't decided if this will be 2 or 4 wheel drive yet. I have a set of 1.9 SXs on a SCX10.2 and they measure exactly the OD as listed in the specs for the tire.
The question is, can someone confirm the 2.2s are 5.40" (137mm) OD per specs and the 1.9 SXs are 4.75" (121mm) OD. I'm hoping the 1.9 XLs and the 2.2s are right on the spec OD. The reason for the question is, if I go with 4 wheel drive these tires match speed perfectly if I run standard rear gearing in the AR60 rear axle and overdrive gearing in the front axle. I'm leaning towards the Super Swampers because the 1.9s and the 2.2s have the same tread pattern.
I'm planning on mounting both size tires to 2.2 beadlocks.
If I go ahead, this Wraith will probably be used more as a parade/mantle queen than a trail/crawler.
Any information appreciated.
