I made mine into a trail rig
Used Loctite liquid Teflon in the diffs,not fully locked but slips slowly just before the slipper clutch.
1/2" wheel widners with 2.2 mashers
Hpi 7:1 gru
the vxl even with the gru cogs at crawling speeds but not too bad.Top speed about 3mph and long run times
wide steering due to the wideners and whimpy servo
On order I have rpm revolver 2.2 wide crawler rims,They fit the 4x4 pede knuckles with no problems,no wideners needed.
Traxxas telluride arms,steering links and upper control arms are a straight swap and will narrow the trucks hex to hex down to about 9" or less,Stock is 9 3/4"
2.2 mudslingers in the mail also
then stretch to fit one of my 1/6 bodies,either the Titan or the f150 fx4.
the design of the single upper control arms introduce a lot of flex in the suspension.I will experiment with double arms.
With the 7:1 gru I can see traxxas shafts breaking easily and stripping out hexes.
the stampede 4x4 vxl version has a 2.6:1 diff ratio,the brushed version has a 3.9:1,the diffs are a straight swap.Go to a parts diagram and get the front and rear diff gear part numbers for the brushed xl-5.Remember that the front and rear diff gears are different designs,dont just order two fronts,fronts wont fit the rear diffs.The 7:1 is a lil too slow on 9 volts,a 3s would be sweet.....once again traxxas plastic shafts are the weak link.Ill post up next week after my parts are installed
