As title states, the LVC is either having issues or spektrum has it programmed ungodly conservative or I'm missing something.
First bit. It was below freezing much of this weekend trip/event.
Same exact packs (I have 4 of these same battery packs, 2 have 1 run each, 2 more brand new) 3s 2200mah 35C Ovonic packs.
Before anyone points at battery packs. I use these in 2 rigs. 1 is the Knightkeeper/Tacoma build build (problem) and the other is the Gatekeeper Hilux.
Tacoma (rig with issue):
Spektrum 2 n 1 2300kv
NSDRC RS800 servo direct powered
Hilux (ran perfect all day)
Hobbywing Fusion 2 n 1 1800kv
Cheap "45kg" servo off Amazon, ran off rx power, thus BEC.
Here's the problem. The Knightkeeper kept going into LVC for no reason. Literally tested full battery just off charger night before. Happened with every pack I put in out of the 4 of these packs I have. Was annoying when I got to the event, fired up, got 10ft from the bed of my truck and it went into LVC.
Driving in a straight line suddenly first stage LVC then a couple seconds to minute later it shut down. Unplug battery, plug back in I could go 2 minutes or 30 minutes before it did it again. So in the course of 2 hours I had to reset the ESC several times.
Tried changing packs, even hooked up my spektrum battery tester/programmer (tester is accurate, I verified with 2 chargers and DMM to make sure when i bought it) and hammered throttle/moved steering, voltages went down but shouldn't have engaged LVC. Then hooked programmer up and set LVC to lowest possible setting without turning off.
Now at the same time using the batteries that acted up, now frozen from being in my backpack, I put in the Hilux and ran for 1.5-2 hrs not a single issue.
Which narrows everything down to The Spektrum Firma 2n1 LVC settings or an issue with it.
I cannot find the actual voltage that the LVC does it thing based on what stage chosen. Looked for 45 minutes so far. Trying to figure out best course of action so I need to test and see what is doing what. But I need the factory specs to see if this is faulty or just some idiot at spektrum programmed them wrong.
Sent from my SM-S906U using Tapatalk
