AngelowDoom
Spektrum DX6R 6-Channel DSMR Smart RC Surface Radio Transmitter System | SpektrumRC
Spektrum DX6R 6-Channel DSMR Smart RC Surface Radio Transmitter System | Horizon Hobby
Coming soon from Spektrum is the DX6R DSMR smart radio system. It offers an Andriod-powered full-colour touch screen, WiFi connectivity for firmware upgrades and Apps as well as 5.5ms frame rates, telemetry functions and Bluetooth model transfer. The wireless link also allows the use of FPV headsets, the ergonomics, including wheel angle and trigger settings, can be customised to the driver’s needs and the 250 model memory allows for more space than most modellers need. The 6-channel radio set includes SR6000T and SR2000 receivers, it comes with a LiIon battery with charging base and it supports AVC programming for compatible receivers.
Price: $499.99
Key Features
– Intuitive, full-colour, Android-powered touch screen
– WiFi connectivity for firmware updates and apps
– Built-In Telemetry
– Bluetooth model transfer for use with other DX6Rs
– Wireless link for compatible FPV headsets
– 5.5-millisecond frame rate with compatible receivers
– Superb ergonomics you can customise
– Voice alerts over speaker or through headphones
– 250-model memory
– AVC programming for compatible receivers
– Includes SR6000T and SR2000 receivers
– Long-lasting Li-Ion battery with charging base
– EN328 compatible
Overview
The DX6R smart radio will transform your driving experience. Touch-screen simplicity, WiFi connectivity, unbeatable DSMR® range and security, 5.5ms frame rates, telemetry, Bluetooth model transfer – you get it all and more..
Android-Powered Touch Screen or Scroller
You can literally 'tap' into the DX6R's programming features using an Android-powered, touch screen. Long-time Spektrum users who prefer the more tactile scrolling selector can use it. Whichever input you use, the big color display makes navigating menus and adjusting settings as easy as it gets.
WiFi Connection for Updates and Apps
When connected to WiFi, the DX6R gets even smarter. You can instantly make firmware and RaceWare™ updates, download model setups from other users and add approved third-party apps. The DX6R will even be able to alert you when new updates or setups become available.
Bluetooth Model Transfer
If you’re out driving with another DX6R owner, you can quickly and easily swap model setups via Bluetooth. No WiFi or SD card transfer necessary. Just link up and swap.
Built-In Telemetry
The built-in telemetry feature can give you real-time information on things like your vehicle's battery voltage, signal quality, motor temperature and more.* Using the voice alert system, you can program the DX6R to tell you when specific telemetry values reach or exceed limits you define. You can also have it call out a sequence of telemetry values on demand with the flip of a switch.
*Vehicle must be equipped with a telemetry-enabled receiver like the included SR6000T.
Frequency-Agile DSMR® Technology
The DX6R is built around frequency-agile, DSMR 2.4GHz technology. This exclusive Spektrum™ technology can be used in any type of surface application, including boats. Its range and response, particularly in noisy 2.4GHz environments, are superb. It's also backwards compatible with DSM2® and marine-specific Spektrum receivers. This means most longtime Spektrum users can continue to use the receivers they have. They’ll only need to upgrade if they want the frequency-agility of a DSMR receiver for busy 2.4GHz environments.
Superb Ergonomics
Optimized weight distribution and an abundance of adjustable features make it easy to customize the DX6R’s ergonomics to your driving style. You will enjoy a sense of balance and comfort that perfectly complements the precision of DSMR technology, especially during long racing heats.
Ergonomic features include:
Multiple wheel angle settings
Adjustable trigger and steering tension
Adjustable trigger position (fore-to-aft and side-to-side)
Left- or right-hand steering
Multiple drop-down options
Three grip sizes
Smooth, dual-ball bearing precision
Wireless Link for Spektrum FPV Headsets
This exclusive Spektrum technology makes it possible to link with specially-equipped Spektrum FPV headsets so you can wirelessly control head tracking or remotely change video frequencies.
5.5-Millisecond Frame Rate
When matched with a receiver capable of 5.5ms frame rates, the DX6R delivers lightning-fast response that gives new meaning to the word ‘connected’.
250-Model Memory
The enormous capacity of the DX6R’s on-board memory means you will rarely, if ever, need to juggle models between transmitter memory and your SD card.
Includes SR6000T Telemetry and SR2000 Race Receivers
You can take advantage of all six channels and telemetry functions with the included SR6000T. A tiny SR2000 Race Receiver capable of a 5.5-millisecond frame rate is also included.
Programmable Voice Alerts
Keep tabs on important information without ever taking your eyes off what you’re driving. With the programmable voice alert system, you can have the DX6R call out lap times or report telemetry information. If an alarm goes off, you won’t have to look at the display to see what’s happening. The DX6R will tell you.
In addition to a built-in speaker, the DX6R has a headphone jack that allows you to monitor voice alerts using earbuds so you don’t bother other drivers.
Programming Features
The DX6R comes with an impressive list of programming features, some of which include:
Up to 3 drive modes per model
AVC® programming for compatible receivers
Programmable mixes
7-Point throttle and steering curves
Voice alert programming
Dual rates and expo
And more!
Charging Base
You don’t have to remove the battery of plug in the transmitter when it comes time to recharge. The DX6R includes a handy charging base that doubles as a transmitter holder. Its compact footprint won’t clutter up your pit station or workbench either.
Price: $499.99
Key Features
– 250-model memory
– EN328 compatible
Overview
Built-In Telemetry
Superb Ergonomics
Three grip sizes
250-Model Memory
Programmable mixes
Dual rates and expo
And more!
Charging Base
