I have 5 crawlers with Holmes Hobbies motors and Hobbywing 1080 controllers. All have Spectrum SR515 or SR215 receivers. Everything works fine off my Spectrum DX5C transmitter.
I built a new car using a Hobbywing Xerun system, 3652 brushless motor, XR8SCT controller, Spectrum SR215 receiver, DX5C trans. The Tx and Rx paired up fine. When I try to calibrate the throttle, neutral, forward, beeps but reverse does not. Turning on the system, if you touch the throttle, it goes to 100% and stays there. Hitting reverse stops it. The steering works fine. I switched receivers to the SR515 with the exact same results. The calibration does not work for throttle. Wide open at the touch of throttle. These are receivers that came off good working cars.
I switched transmitters to a FlySKy GT3B, and FS receiver. First try everything works with the Hobbywing Xerun system, throttle and steering.
Is there a inherent problem with the DX5C and HW Xerun system? Or does anyone know what I am doing wrong? I was reading about using a BEC, does anyone think this will cure the issue? Or switch to another brand?
