Soze adds an Enduro Sendero RTR to the fleet.
soze
Orange County, CA
I don't RTR often, but the Enduro looked like one that was worth RTR'ing. I plan on getting the kit as well, but this will be my RTR progress for the Enduro.
Follow my Enduro RTR on YouTube
Most links below are to eBay. As an eBay Partner, I may be compensated if you make a purchase.
Kit:
Element Enduro Sendero RTR - https://ebay.to/2N4IMUF
Parts:
SSD RC 25T Clamping Metal Servo Horn (eBay) - https://ebay.to/37944XY
Pro-Line 1.9 BFG Krawlers G8 Compound - https://ebay.to/3pe9qrt
Pro-Line Dual Stage Foam - https://ebay.to/3jIoCM6
1.9 Beadlock wheels - https://ebay.to/3pgUoRN
SSD RC Enduro Brass Knuckles SSD00357 - https://ebay.to/2NkMiKB
SSD RC Enduro Rear Axle Weight SSD00354 - https://ebay.to/3d9rW1t
Club5 Racing Enduro Shock mount support - https://ebay.to/3rPjVDi (eBay)
Club5 Racing Enduro High Clearance Links - https://ebay.to/3tTuQgY (eBay)
Club5 Racing Enduro Steering Links - https://ebay.to/2N4ujrM (eBay)
Club5 Racing Enduro Shock bushings - https://ebay.to/3d8T7tm (eBay)
REVolutionX High Clearance Mid-chassis brace - TBD
REVolutionX Rear Chassis brace for IERC Shorty Bed - TBD
** GMADE BOM Rear Cage Setup **
GMADE BOM Rear Cage Kit - https://ebay.to/3b1di9Z
GMADE BOM 324mm Rear Links - https://ebay.to/3qhoLZw
Boom Racing Shock Keys - https://bit.ly/2JvvwnE
Axial WB8 Driveshafts - https://ebay.to/3qgoPbZ
Element Enduro Yellow Springs - https://ebay.to/3jJA8qs
** IE-RC Rear Bed Setup **
Element Enduro Sendero Clear Body - https://ebay.to/2Nk4tjq (eBay)
IE-RC Shorty Bed for Enduro - https://bit.ly/2J6Yidd
IE-RC Head Rack - https://bit.ly/2QC44ro
IE-RC Shock Towers for Enduro - https://bit.ly/2UbCKCI
Pro-Line Overland Roof Rack - https://ebay.to/3tWKKY6 (eBay)
N52 Grade Neodymium Ring Magnets 1/2",1/4",1/8" - https://ebay.to/2N1BTU5
Electronics:
Hobbywing WP-1080 Brushed Crawler Esc (ebay) - https://ebay.to/2Z8RiVm
FlySky FS-R6B 6ch Receiver - https://ebay.to/3qdJGg3
FlySky GT3C Transmitter - https://ebay.to/2NlfqBa
DS3218 20kg Servo (ebay) - https://ebay.to/37bIHFD
HobbyStar 3700mAh 3S - https://ebay.to/2Nob1xl
Tools:
Versachem Brake Caliper Grease - https://ebay.to/3p8bIZ7
Noleen SF3 Grease (available on eBay) - https://ebay.to/3jN9vB9
Permatex Anti Seize Lubricant (ebay) - https://ebay.to/3qpTbsN
Associated 1656 FT 1/4 in Driver Handle - https://ebay.to/3d31t5O
Tamiya Side Cutter - https://ebay.to/371SAWb
DEWALT DCF610S2R 12V MAX Cordless Lithium-Ion 1/4 in. Hex Chuck Screwdriver Kit - https://ebay.to/3tQqXcr
MIP Metric Speed Tip Set MIP9512 - https://ebay.to/3qdBMTU
Bob Smith Industries Blue Thread Locker - https://ebay.to/3jDR8i9
ProTek RC Shock Pliers (available on eBay) - https://ebay.to/372Lscs
Duratrax Shock stand - https://ebay.to/2MOyJ6l
Hakko FX-888D Soldering Station - https://ebay.to/3aXFmLj
Multistar Rubber R/C Work mat - https://bit.ly/2T3F4Zo
IWISS Crimping Tool - https://ebay.to/3jGKZll
Universal Servo Cable Wire Connector Crimp Pin Kit - https://ebay.to/3tSAAaW
E6000 Adhesive - https://ebay.to/2MZwtZV
Paint:
Tamiya PS-30 Brilliant Blue - https://ebay.to/2NhRsqL (eBay)
Tamiya PS-5 Black - https://ebay.to/2Zbup3i (eBay)
Tamiya PS-55 Flat Clear - https://ebay.to/3rPBG5p (ebay)
So after noticing some shaft play in the stock servo, I decided to swap out to the DS3218 20kg servo along with a SSD RC 25T clamping metal servo horn. I'll eventually get a stronger servo, but the 20kg will do for now.
The stock Enduro bumper is huge one the Enduro. The stock bumper on a SCX10.2 Cherokee is pretty big as well on a SCX10.2.
Stock JCR Offroad bumper from the SCX10.2 Cherokee kit is much smaller when mounted on the Enduro, than the stock Enduro bumper. I'll stick with this for a while until the bumper I want eventually shows up for sale.
https://youtu.be/ONyEJ3YkSB8
<iframe width="560" height="315" src="https://www.youtube.com/embed/ONyEJ3YkSB8" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Time for the 11.83% overdrive gears (26T/54T) to go in. Stock is 5.7% (27T/53T) overdrive.
11.83% Gear set. 26T/54T gears.
You'll first need to disconnect the driveshafts from the transmission.
Next, you'll need to remove the screws from the skidplate. Pay Attention! The skid uses 4 screws. 2 long ones, and 2 short ones. The longer ones are used towards the middle of the skid plate. The shorter ones closer to the frame rails. When you put it back, make sure you put it back properly or else you'll be gouging your gears.
Transmission is out of the truck
A look at the tiny skid
5 screws to remove to get to the gears.
The gears as they are inside. You'll be replacing the 2 gears closest to the spur gear. Leave the 3 gear row alone!
11.83% 26T small gear vs 5.7% 27T small gear
5.7% 53T big gear vs 11.83% 54T big gear
54T gear greased up and put back in
26T greased up and ready to go
All the gears put back. (In hindsight, maybe I should've wiped off the old grease and re-greased all the gears)
Transmission buttoned up and ready to go!
Make sure your driveshafts are in phase when you put them back.
11.83% Overdrive ready!
Great info here Soze!
I plan to pick my RTR up tonight after work from my LHS and I plan on doing the overdrive first thing so this info will help.
Thanks Soze!
Great info!!! you'll have ta let us know if there is a noticeable difference between the two!! at least I wanta know!! All this great info around here on the truck I might just have to pick one up!!! been lookin for a 1.9 anyway.
if this is how its gonna be, i'll just beat soze to the cage stuff lol
come on guys lets just enjoy the truck and not worry about who posts what?
B-mow im picking mine up from my LHS after work today too! and a "build thread" or "RTR improvement program" soon after ;)
I can put it in there as well? Thought you might have wanted to keep it limited to free upgrades that are "MacGyver" in nature.
You have good upgrade info so yeah, it would be great to compile it. I'll just link back to threads cuz peeps seem to want their own thread, I get it. I'll start a list once the threads get spread out in the section, add yours and others, whomever gets some good content going for all modifications and upgrades. Every once in awhile stuff shows up on FB too, at least pictures and comments - can capture those too.
Thanks!
PS - We're hitting CDM Friday, 9-noon or so, beat the crowds. My floating holiday. ;-)
