monkeyracing
Spektrum's released a firmware update to address 4WS and MOA issues, among other things. Cool. Here parts of the blurb they sent me...
"Software Features:
Added Motor on Axle (MOA) pre-set mix with graphic display to simplify setting up a mix for crawlers with dual motors. Drive types (rear wheel, four wheel and front wheel) MOA is switch selectable via a programmable switch plus throttle bias is available to adjust front to rear power delivery on the fly
A Graphic Steering mix that includes front, 4-wheel conventional, 4-wheel crab and rear steering has been added. Steering type is selectable via a programmable switch
Added indicators on the main screen to show the active MOA and 4WS modes and throttle bias percent
Software Corrections:
Changing expo is now independent of travel
Corrected minor fluctuations in the throttle and steering values on the monitor screen when the backlight is on
Aux channel positions are saved when the transmitter is powered off
If the DX4S is bound to an SR3300T without any telemetry sensors connected, the temp overheat warning will not be displayed
Powered off issue has been corrected
Boxing correction in the brake Mix menu
In the System -> About screen, the grouping of the S/N characters has been changed"
"Software Features:
