distress
Since there's no Brand Specific section for the 1/24 ECX Temper Micro Crawler I posted this here.
Share your builds and mods!
Here's one of mine:
Chassis is a TCS pebble made for a Losi MCRC chopped up with a styrene roof and 35mm M2 standoffs to stabilize and space the vertical plates.
To lengthen it I used the longer bottom links as the tops and made bottom ones from rod ends and bulky M3 Rod. The best way is M2 rod with Losi Mini-T ball studs and rod ends but I didn't have any.
I extended the driveshafts but cutting them and using a piece of a bic pen.
Bottom plate is JB Welded for weight and low CG and because the little tabs tend to break. On mine I drilled through to put an M2 rod through the balls (didn't have ball studs).
Moved the shocks inward at the top for articulation (with M2.5 standoffs and screws with the ball stud screwed into the other side) because they hit otherwise on a stock Temper. It's also good to move the chassis-side end of the top links inside for triangulation but it wouldn't work with this TCS chassis. (Does work with the stock plates and eliminates side to side swing.)
Stock wheels and full sag for now.
Here's one of mine:
