Setting up Two Position DIG on Capra - Help Please
Texas_Jester
Lumberton
So this may be a totally stupid question, but I am way behind on understanding electronics. Just built a Capra with DIG function, have an SRM-315 Rx and a Spektrum DX5C Tx. I have the DIG Servo (Spektrum SX-107) plugged into the AUX1 port of the Rx.
So I have tried to program a momentary button (in my case G) to the AUX1 function on the Tx expecting it to rotate the DIG Servo when pressed and to keep it in a fixed (4wd) position when its not depressed.
Nothing happens at all when I engage the G (AUX1) button on the Tx. Is there a possibility that one of the other AUX channels would feed this AUX1 port on the Rx or what else could I have going on that it won't work?
Also, I set the limits to 30% to start out so as to attempt not to burn up the servo and I do have the servo saver in place. I can't sort what would possibly be wrong.
Any help is appreciated.
Programming the DX5C is a nightmare. My first suggestion would be to try a different button for it, see if there's any luck there. After that, I would try plugging a different servo into AUX1 to see if it works-- there's a fair chance the SX107 has already died. Mine didn't last a full pack.
If I remember correctly, G is momentary only, and may have to have the throw reversed to make it work. I've set up a DX5c on a 10.3 Gladiator, and a Capra and have it that way on my 4-10 Ultra.
No, G can definitely be used as a switch-- I use it for the 2-speed on both my TRX-4s.
I will say that for the Capra dig servo, setting the center and endpoints is absolutely critical. The full-size servo I'm now using uses less than 30% of it's total throw-- I mean, the total distance between 4WD and dig is like 8mm.
The BIGGEST problem with the dig (Capra & SCX10-III) isn't setting it up...it's the piece-of-garbage SX107 servo. The BEST suggestion/recommendation is to replace it asap, work something like the Reef's 99 or Power HD TR-4. As for the SX107 'specific' servo saver, something Axial/Horizon Hobby doesn't like to let people know (though, some support personnel will tell customers) is that there IS a servo saver kit that includes multiple lengths of the upper piece, plus multiple standard-size lower (spline) pieces - AXIC3009.
This allows you to use ANY micro/mini/standard size servo with the Capra/SCX10-III dig. While the stock skid can only fit a micro, there are 3rd-party skids (mostly 3D-printed) that are designed to hold a standard servo.
~ More peace, love, and kindness would make the world a much better place
'G' should work, but you might have to reassign the timer function first.
Dumb question, but do you have the servo linkage disconnected when you are trying to set all of this up?
Thanks I started it at 10% limits but its not acting like its getting any signal
Good to know, I did order another servo that I am going to try
Not following the "reassing the timer function" can you expound on what that is and how, exactly to do it?
And yes I am setting it up with it disconnected and sub-trim limits set down at 10% for starting points, thanks!
Default function for SW-G is the timer start/stop. Assigning an AUX channel to SW-G should be fine, but sometimes the radio gets confused. To correct this, scroll down to 'Timer', select it, and reassign that function's switch.
Next, when you go into the 'AUX Assign' menu, go to AUX 1, and select Input to -G-. Then scroll down under Momentary and select 'Active'.
