Hey I'm new to the rc crawler world. Ive bought a 1/8 RTR Madtorque from Exceed last winter. Just bought it to play with and screw around on some local rocks. Recently I added 4ws to the crawler and my first run with it I cracked the plastic housing inside the servo that goes over the motor gear.(on the front) The original Servo was a crappy 9kg with metal gears. I figured it was because it was almost a year old and its stock and most stock everything is crappy. So I bought a 12kg servo with metal gears. Installed it on the front. My 3rd run on this new servo and I stripped one of the metal gears. Boooo. So I am to wonder, Is this all because they are cheap servos and I should invest in a better servo like hitec or something similar. Maybe with titanium Gears? Ive done some research and I see alot of guys run T-Pro just for the fact they are half the cost of Hitec. And I am curious why is it the front only? I havnt had any issues with the rear steering yet. I am currently running 2.8 tires with no weights and my rig is fairly light. Its a MOA Rig. Ive checked to make sure nothing was too tight, as far as my steering knuckles and tie rod / links. In case it matters, I am using a NIMH 6-Cell Battery Pack 7.2V 4000mah.
So would I be better off on getting a servo with:
Generic Brand Servo
Savox SC-1256TG High Torque Titanium Gear Digital Servo .15/277
This is the Savox SC-1256TG High Torque Titanium Gear Digital Servo.
Specifications and Features:
How about:
Hitec HS-5645MG High Torque Metal Gear Servo
Specs & Features:
Motor Type: 3 Pole
Bearing Type: Dual Ball Bearing
Speed (4.8V/6.0V): 0.23 / 0.18
Torque oz./in. (4.8V/6.0V): 143 / 168
Torque kg./cm. (4.8V/6.0V): 10.3 / 12.1
Size in Inches: 1.59 x 0.77 x 1.48
Size in Millimeters: 40.39 x 19.56 x 37.59
Weight ounces: 2.11
Weight grams: 59.82
I am leaning towards something with Titanium Gears since I stripped the metal gears out of the last one.
Thanks for helping a Newb.
Generic Brand Servo
- Torque @ 6.0V: 220oz (16kg), Torque @ 4.8V: 206oz (15kg)
- Speed @ 6.0V: .16 sec, Speed @ 4.8V: .18 sec
- Weight: XX / XX oz
- "J" type connector with approx. 5" wire
- Standard size servo
- Combines leading edge technology with super high 12 bit (4096) resolution and titanium gears.
- Super light-weight.
- Coreless motor provides high speed, incredible efficiency, and low power consumption.
- Titanium gears ensure long life and durability.
- The aluminum case design not only looks good but also allows for cooler and smoother operating temps.
- Our servos are totally green – from materials to production, these servos are environmentally friendly.
- Ideal for steering applications in 1/8 scale buggies, monster trucks and rock crawlers.
- Dimensions(mm): 40.3x20.2x37.2
- Weight(g):52.4
- Speed(@4.8V sec/60): .18
- Torque(@4.8V oz-in): 222.2
- Speed(@6.0V sec/60): .15
- Torque(@6.0V oz-in): 277.7
- Gear: Titanium & Aluminum
- Bearing: 2BB
- Case: Aluminum
- 25 Tooth Spline
How about:
Specs & Features:
Motor Type: 3 Pole
Weight ounces: 2.11
Weight grams: 59.82
