Genghis Ken
So, I’ve watched Harley’s and Scale Builders budget build off and found them very helpful. But I’m curious about some of the weight vs performance trade offs and how they scale down to 1/24th. I watched a scaler comp of 1/10th scale rigs and virtually all of them had aluminum axles. Non rotating mass weight down low it makes a lot of sense plus the rocks those guys were crawling were just gnarly so the extra strength and ability to take punishment was also a big plus. So what about in a 24th scale rig? Does it make sense in a rig that can’t actually do the things the 1/10th scales can? I mean yes they can do some pretty cool crawling, but is it better to keep them as light as possible and only add the minimum weight needed? And if so would an aluminum axle trump a brass diff cover and brass knuckles? I’m also seeing brass wheel weights and brass hexes which get into rotating mass which was one of those things I thought the current thinking was to avoid. So basically where’s the best place for the weight to be? I’ve seen a brass axle, would that be better than brass steering knuckles, dif cover and wheel weights? In theory it’s more centralized weight so maybe yes? I dunno, so for you guys that actually crawl yours what seems to be working the best and why, and if you had to do it over again would you go the same route or are there new items out now that you would go with instead. For what it’s worth I’m planning on a stock ish C10 and a Deadbolt set up for the best crawling it can do. Money is limited so getting the best bang for my bucks is important and I live in the UK so I can’t go nuts on a main and get free shipping and likewise making gradual updates is gonna come at great cost in shipping. See why I need your help?
