SCX24 Based 6x6
AK KRAWLER
North to Alaska - go north, the rush is on....
Okay, I need another project like I need a hole in y head...But started gathering parts anyway...
I will likely keep this as the "build" thread and have a question regarding metal axle housings and associated internal parts.
I see the prices vary pretty widely from about $25 per axle housing, on up to around the $50 mark. Is there a large enough difference between the $25 Yeah Racing Housings and the more expensive Hot Racing housings and the CNC version of the Yeah Racing housings?
With having 3 axles, I'd rather not buy all the most expensive stuff...
I have enough rigs, that one rig does not get all the abuse, all the time, so I think just about anything I build will last a long time.
With all the other irons in the fire, this will likely take a back seat regarding finishing, but if I have parts on hand, I can at least start some of the assembly.
Well, last night I pulled the trigger on 3 stock axles. It will help me with the mock-up, was a bit less expensive and now I have all the internals for when I grab the aluminum housings later.
I will likely use a new front and rear axle assembly on the C10 build for the wife and then use my old set of axles and a third new rear assembly on the 6x6.
That way, she gets new shiny stuff "thumbsup"
Initial thoughts:
Chassis - MoFo R/C LCG 333 6x6
Motor - Surpass 1200kv or 1400kv
ESC - Furitek Tegu
Servo - Emax
Tires - TBD
Wheels - TBD
Body - TBD
