SCX10ii Body Mounts for the RC4WD K5 Blazer Body
RexRacer19
Let me 3D Print that...
Concord
Mod19RC is now offering a new option for mounting the RC4WD K5 Blazer or Pickup Cab to the Axial Racing SCX10ii chassis. These mounts are printed through Shapeways using SLS Nylon for strength, durability, and quality. They attach directly to the SCX10ii chassis using the factory screws.
These mounts are designed with scale builders in mind and feature a unique body mount tab that can be mounted four different ways to help get the exact look and tire fitment to suit your build. They are ideally suited for builders using a front motor conversion. If you plan on keeping the stock AX10 transmission and using the Blazer interior, note that it will need to be modified to clear the spur gear and back plate.
The left and right sides must be purchased separately (to keep print costs down) and each includes a body mount tab. Additional body tab sets can be purchased separately if mounting multiple bodies to the same chassis.
Pricing for the set (both sides) will be $48.98. You will also need to provide the (4) stock M3 x 8 screws from the Blazer body along with (4) M3 x 10mm Flat Head Socket Cap Screws to attach the body tabs to the mounts.
Hit the Shop Now button at the top of the Mod19RC page or follow the link below to the Mod19RC Shapeways store.
https://www.shapeways.com/shops/mod19-rc
Will this line up with the UMG10 chassis?
It would. The front end geometry/links on all the SCX10ii chassis is the same. The body mounts center on the front wheels. You can then adjust the wheelbase in the rear to fit a blazer or pickup.
Also, I am giving away a set of these mounts in the General Crawlers section. Post up in that thread for a chance to win!
