TFitzPat87
Hi All,
First time poster! This forum has a wealth of good info, so I decided to join.
I'm working on my first RC. It's the SCX10 II Jeep Cherokee. Never had any plans on getting into RC, but I came across the above kit and couldn't pass it up. Love tinkering with things and I'm a die hard Cherokee (XJ) fan so it seemed right.
Anyway... on to my question here. I'm currently in the building process. I pretty much have the axles completely built with the exception of the steering linkage. Everything went together nice without much issue except one thing... the front axle has a small bind in it. About every 2.5 to 3 rotations of the output shaft from the axle (pinion shaft to drive shaft) it has a small bind. I can spin threw it fairly easy (sometime it catches/binds pretty good and a little more effort is required), but I can definitely feel that it's "catching". I didn't see any issues on any of the gears during install so not quite sure the problem. Since I'm new to this I initially thought it might be normal, until I spun the rear axle and that one is smooth as silk.
What should I be looking for? I have yet to open the axle back up and don't want to if I don't need to. That being said, I'm more than happy to break it down to make sure it's operating properly.
Thanks in advance!
Fitz
Thanks in advance!
Fitz
