scx10 driveshaft help
colin1986
Australia
does anyone know of a fix for the grub screws on the driveshafts mine keep coming out even with lock tight in them any tips or alternative suggestions would be greatly appreciated
im having the same prob thought it wouldnt be so bad but i have to put them in each time i get it out.
any tips or fixes welcome
not sure about red loctite as if they need to be changed it would be a bugger to get off. i was thinking putting another grub screw in the other hole as there are 2 but then i need to find some grub screws.
same here need more grub screws
I bought some longer grub screws, i think 3mm. I use blue lock tight and let it dry over night. It has never loosend up yet. Im running a ballistic 8.5t with 14mm rotor!
I got the grubs from my LHS. I think they were 3mm x 4 or 5mm long. Just take one with ya and make sure it fills the whole theads on the yoke.
I had the same problem with mine. So I just put a dab of hot glue on it. It takes a while for the glue to come off, and if you need to take off the drive shaft , just use rubbing alcohol to release the glue. Hope this helps.
