JOSH1973
So, the other day i had just finished building my rc4wd Gelande 2. The electronics I have are......ESC:Novak rooster,Motor:Axial 55t, Servo: Axial AS-3, Battery- racers edge 5500mah nimh. The only thing that is brand new is the esc. Anyways, I start doing some light crawling with it for the first time, and everything is running great. After about ten min. it starts to freak out, the servo is going back and forth on its own, along with the esc, and i have no controll with the radio. The car goes back and forth rapidly a couple times then stops. Once it does, the radio is not having any affect on it. Also i start to see smoke coming out by the battery. After I take it inside, unhook the battery and plug it back in, the esc works fine. The car with goe forward and backward just fine, and the drag brake seems to be working fine. However, the steering is dead. The servo wount move at all. I can smell ohms burn on it, so I assume its dead. Also the battery connector(both the male and female side) are burnt up on the inside. BUt it still functions(im going to replace them to be safe). So im wondering if anyone knows what the hell happened. I ordered a high torque savox servo to replace the bad one. BUt im wondering what caused the incident in the first place? Was the axial servo just not up to the task and burned up, cause the whole system to freak out for a min? I just dont wanna put the 80$ savox in the thing to have the same thing happen.
