camoTJ
Alright so I had my front apart putting new belts on the axle and the "servo" and noticed that the front motor is above the axle. So off to work I went with the dremel on the rear
cut about 1 1/2" maybe alittle more off. havent measured it yet
then were I mounted the motor. Cut a slot through the housing where the belt need to go through. Then I tensioned the belt how I wanted it and mounted the motor
then just using some tin that I had went ahead and closed off that huge gap I just cut in the housing
Then I closed in the motor to make it look alittle cleaner
still need to finish up the wiring (just twisted the ends together last night to test it) and do alittle more tin work to finish things off. Its nice being able to drive straight up curbs and stuff now, and actually having the back tires hit first instead of the axle
